Anyone with a Ranger running 33's? Need advice! | Ford Explorer Forums
Nowayranger
Washington
'97 ranger XLT 4x4
I have the f150 coil spacers in front, and 2" shackle lift in back, I was wondering if anyone has a similar set up and is running 33's or bigger? Im running 32" all terrains right now, but id like to look into getting a set of more aggressive off road tires, and idk if i should stick with 32's or if i can go for 33's with the lift i have? Cause if i can, bigger is better so... lol!
Thanks!
does it rub when off roading with the 32's ?
how much space between the wheel and the fender ?
Just got my coil spacers on yesterday, havnt been off road yet :( but w/o the spacers it only rubbed a little bit if i hit just the right spot at about 3/4 turn and at mid speeds. Havnt had them rub with the spacers taking corners hard or anything now. Theres 5" from top of tire to the fender, and the tire to the rear part of the fender there is 3" (outside edge of the rear part of the fender was where it used to rub)
if it rubs with 32's a bit of trimming and the 33's will fit,
