APIM, extended warranty by ford
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
I just received a letter from ford that the warranty on the apim has been extended for 5 years to selected explorer, i have not had any issue with mine but they sent me the extended letter. Anyone else ?????
GWA1
New Castle, DE
2011 Explorer Limited AWD
Haven't seen a letter yet but I read awhile ago because of all the problems with SYNC/MFT that they extended it. Although I thought is was all Ex's not "selected" ones.
I guess that could mean 2011/2012 but not 2013.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
It better be for the 13my its worse then my 11my.
Edgieguy
New Jersey
2011 XLT / 11 Edge Sport
I got two! One for our Edge and one for our Explorer!
flyleclair
Bath, Pa
2011 Explorer XLT 4WD
Just received the letter and MFT upgrade letter today.
phareous
Charlotte, NC
2013 Ford Explorer Limite
Yeah I got the letter...hopefully I won't need it :)
1995E
Maryland
95 + 11 Ex both XLT
So I got this in the mail a while back and I am wondering why they are extending the warranty on the APIM from 3 to 5 years? Is this because the APIM is at fault to most of the MFT issues? Seeing how the software can run flawlessly, it seems like it's a hardware issue sometimes. I mean the first MFT software was s**t, no doubt about that with it not using the onboard graphics processor and relied everything on the cpu to do the work. However, I had my APIM replaced twice already, and it really concerns me. Is Ford going to redesign the part and make sure we don't have to deal with this? I'd really like for the APIM not keep dying. Especially since the last time it happened, I lost all power for a second or two while on the highway with my dad.
Does anyone know what is actually failing on these APIMs that Ford keeps replacing?
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
No clue what is failing within the module. Fortunately my MFT has been nearly flawless. I've had one black screen of death and one reboot on its own in the 2 years and 39,000 miles now on our Ex. We use voice control, nav, ipod connections and weather/calendar functions.. With the little annoyance of not knowing every voice command, it has been performing awesome.
I bought an ESP through Ford because of all the electronics and for peace of mind.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
The link below explains the extended coverage.
For those reading this and who are not familiar with the Accessory Protocol Interface Module (APIM) it is the brains of the SYNC/MyFord Touch system and consists of 1,062 components most of which are located on the main circuit board which is enclosed within a 2 piece aluminum cover.
http://allstatetrucks.com/images/Recalls/R12M02 11 thru 13 Models with Sync and MyFord Touch.pdf
The photo below was taken by our member Sgt1411 and is part of a larger photo album.
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
Peter k9 were do you find the apim?
peterk9
Staff member
Moderator
Callsign
VE3
I believe it is mounted against the firewall under the dash. That picture is not mine. It was one of a series of photos that was posted here at one time and were taken by a Ford employee, I believe.
If I'm wrong in the location and another member knows, please post.
Thanks
sciond
The Q.C.
2013 Explorer Sport
My new APIM is on order...
tgunn_ocs
Cleveland, Ohio
2013 Explorer Sport
How doyou know if you need a new APIM?
sciond
The Q.C.
2013 Explorer Sport
1995E
Maryland
95 + 11 Ex both XLT
So... I'm wondering after all this time, is Ford going to redesign the APIM at all? It sounds like if it's anything that is the biggest failure, it would be hardware. It'd be nice to know that I won't rely on the warranty when my APIM decides to die on me again since I've gotten it replaced twice.
peterk9
Staff member
Moderator
Callsign
VE3
I'm just curious to know if these faulty units are being sent back to Ford for evaluation to see what it is that is failing. I suspect that they are just being disposed of by the dealers.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
That was a photo that I took at the 2011 NA Ford Fleet Preview inside the Dearborn MI HQ Product Development Center.
During the customer Ride & Drive they had an Explorer cut in half to show the insides.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
R APIM reset for Ford Escape Stock 2011 - 2019 Ford Explorer Discussion 3
B APIM Provisioning Stock 2011 - 2019 Ford Explorer Discussion 6
B Question/Clarification on adding HD ACM and the necessary reprogramming of APIM and ACM Stock 2011 - 2019 Ford Explorer Discussion 4
deewan Faulty SYNC/APIM causing battery to drain??? Stock 2011 - 2019 Ford Explorer Discussion 16
Sgt1411 APIM Warranty Extension? Stock 2011 - 2019 Ford Explorer Discussion 1
H apim replacement made backup camera not work as well Stock 2011 - 2019 Ford Explorer Discussion 31
J 12 wks/11,000 miles..1st the cooling fan assembly at 4,000 miles and now the APIM Stock 2011 - 2019 Ford Explorer Discussion 9
R Power-off reset or a dead APIM/How to fix Sync Stock 2011 - 2019 Ford Explorer Discussion 5
C Preventive water pump replacement or extended warranty Stock 2011 - 2019 Ford Explorer Discussion 6
A Ford Extended Warranty Stock 2011 - 2019 Ford Explorer Discussion 4
E 2018 Platinum Extended Cargo Cover? Stock 2011 - 2019 Ford Explorer Discussion 3
L The Value of the Ford ESP Extended Warranty Stock 2011 - 2019 Ford Explorer Discussion 9
S Hard starts, extended cranking time, fuel smell Stock 2011 - 2019 Ford Explorer Discussion 13
A Thoughts On "FORD PROTECT" Extended Service Plan? Stock 2011 - 2019 Ford Explorer Discussion 22
W 3.5 EcoBoost Extended Idling Stock 2011 - 2019 Ford Explorer Discussion 6
D Extended Warranty Calls Stock 2011 - 2019 Ford Explorer Discussion 8
J Is an Extended warranty (ESP) worth it? Stock 2011 - 2019 Ford Explorer Discussion 61
peterk9 Deadline to Order 2014 Extended Stock 2011 - 2019 Ford Explorer Discussion 19
U Ford Explorer Extended Warranty purchase Stock 2011 - 2019 Ford Explorer Discussion 4
E Extended Warranty - Did you get one? Stock 2011 - 2019 Ford Explorer Discussion 11
Flounder Ford Extended Service Plans (ESP) Stock 2011 - 2019 Ford Explorer Discussion 587
T Extended Service Plan (ESP) prices comparison thread Stock 2011 - 2019 Ford Explorer Discussion 232
M ESP Warranty - vehicle miles Stock 2011 - 2019 Ford Explorer Discussion 2
T PTU issues covered with ESP Warranty? Stock 2011 - 2019 Ford Explorer Discussion 3
B Salvage Title Warranty? Stock 2011 - 2019 Ford Explorer Discussion 5
0 Motorcraft warranty Stock 2011 - 2019 Ford Explorer Discussion 3
J Transmission leak not covered under 5 yr/50,000 powertrain warranty?! Stock 2011 - 2019 Ford Explorer Discussion 22
T Center wheel cap finish bubbling- warranty item? Stock 2011 - 2019 Ford Explorer Discussion 4
S Warranty on Ford Battery? 2016 Exp Sport Stock 2011 - 2019 Ford Explorer Discussion 34
O Ford Dealer doesn't want to cover warranty :( Stock 2011 - 2019 Ford Explorer Discussion 30
J What Is It With Dealers and Warranty Work Stock 2011 - 2019 Ford Explorer Discussion 1
M Ford ESP Warranty or Not? Stock 2011 - 2019 Ford Explorer Discussion 7
S Recall and warranty quesiton Stock 2011 - 2019 Ford Explorer Discussion 4
K Stiff-armed by the dealer on a warranty issue Stock 2011 - 2019 Ford Explorer Discussion 43
M Bringing vehicle in for warranty work Stock 2011 - 2019 Ford Explorer Discussion 7
D Tuner vs Warranty? Stock 2011 - 2019 Ford Explorer Discussion 1
J warranty question... Stock 2011 - 2019 Ford Explorer Discussion 10
M 2011 limited stretched timing chain, weeks out of warranty. Stock 2011 - 2019 Ford Explorer Discussion 8
S CPO Warranty question Stock 2011 - 2019 Ford Explorer Discussion 3
N Warranty Expiration Intentional from Ford Service? Stock 2011 - 2019 Ford Explorer Discussion 4
K Powertrain Warranty... Stock 2011 - 2019 Ford Explorer Discussion 1
DeLeSaAZ Does tinkering/adding this/that affect warranty OR ESP? Stock 2011 - 2019 Ford Explorer Discussion 8
F Conflicting warranty info Stock 2011 - 2019 Ford Explorer Discussion 10
A My sport is in the dealership for warranty work for vacuum leak. Rental? Stock 2011 - 2019 Ford Explorer Discussion 18
K Warranty Question.... Stock 2011 - 2019 Ford Explorer Discussion 14
D Good warranty service Stock 2011 - 2019 Ford Explorer Discussion 3
F First warranty repair, A/C pressure tranducer Stock 2011 - 2019 Ford Explorer Discussion 8
E Will Ford reimburse for parts if you replace yourself? (Warranty) Stock 2011 - 2019 Ford Explorer Discussion 12
W Warranty Start Date Stock 2011 - 2019 Ford Explorer Discussion 14
K Leather Seats and Warranty Stock 2011 - 2019 Ford Explorer Discussion 9
Similar threads
