caravanmad
- June 29, 2009
- 1998 explorer 4.0
i recently ask for advice on self lev susp the light kept coming on after every 10 miles. i found the pump was burned out, so i replaced with a recon pump, it works however the arc llight again came on, checked for leaks none relays seem to be ok. so i looking at dis box but its a diff layout to mine, i have a 1998 model, but this has a 1997 dis box in it, will this be a problem. in the meantime i pulled out mini fuse 5 and maxi fuse 12 its this ok. i think poss box has been changed and cuold this be wired diffrent, please help
