ARC sensor and lift | Ford Explorer Forums
ARC sensor and lift
Langley91
Bristol uk
1999 ford explorer northf
Im looking at either puting some warrior shackles on or getting some old man Emu leaf springs, but in order to maintain the ARC system, i assume the sensor position needs to be modified.
So, do i need a plate or something to lift it, and if i do what would the thickness be required? If im doing a 40- 50mm lift would a plate of the same thickness be needed or is there a ratio that anyone is aware of.
Many thanks
sam
Was told its trial and error! I built some shackles with a 2 inch lift and used a nylon wedge of aprox 1.5 inch this seemed to work for me!
