nitro71
- April 30, 2009
- Spokane WA
What do you all think? I've only driven a Explorer with ABS brakes but am thinking of converting mine to non-abs. Does the ABS work well in the winter? Is it noticeably better than the non-ABS brakes on 91-92 Explorers?
The reason I'm asking is I'm still experiencing pulling to the left under moderate braking occasionally. It happens intermittantly. I've replaced calipers, shoes and one suspect brake line to no avail. I suspect something is wrong inside the ABS unit but don't know how it operates. I could swap in a junkyard ABS unit but don't want to pay Ford the $50 to bleed it. So my options are pull the ABS parts and put in the non-abs lines or fix my ABS unit or replace it.
