(At-home) Transmission fluid exchange
HISSIN50
'03 MM
Hello,
I've been scouring the old threads but can't find a write-up on doing an at-home trans fluid exchange (2003 Mounty, 4.0, 2WD). Does anyone have any threads saved which outline how to do this? I'd rather not have to guess and test which line to disconnect up front and so on.
Thank you
Join the Elite Explorers for $20. Gets rid of the ads!
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
It wouldn’t surprise me if there isn’t one for your exact model. They are all basically the same. The top line on the cooler is almost always the the hot line coming from the transmission.
Just be careful to not run the pump too dry.
  • Like
Reactions: imp
HISSIN50
'03 MM
Thank you for the info!
I could not find a tutorial for any of the trims in the 3rd gen forums. I know guys do fluid exchanges, and reading a tutorial for any tips and tricks is always nice (like how many quarts you can expect to drain before needing to shut the car off and refill, etc).
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
Drop the transmission oil pan, change the filter, clean the oil pan and magnet, this is also a good time to inspect for debris in the bottom of the pan, then install clean pan with new gasket (if the old gasket is not re-usable ), then re-fill fluid to appropriate level.
Mbrooks420
High Voltage.
EF Vendor
If I dropped the pan I’d replace it with a pan with a drain (or add one).
Is there a reason you want to do this outside of routine maintenance?
HISSIN50
'03 MM
It appears as though the pan has a drain, it's integral to the filler stovepipe in the middle of it. Since you mentioned it, I am having issues finding a replacement gasket/o-ring for the drain plug (just in case I need it). If I had one of those, it could encourage doing multiple pan drains. The more thorough method to replenish all the fluid is obviously to simply exchange it all, however.
I did a pan drop and filter change and now I'd like to do a fluid exchange. Just routine maintenance.
Mbrooks420
High Voltage.
EF Vendor
I would have done the flush first. Just pull off the top hose and pump out 2-3 quarts at a time. Measure what comes out, put the same back in.
S Sevice transmission at home? Stock 2002 - 2005 Explorers 10
O Home Link and Air Bag light. Stock 2002 - 2005 Explorers 0
L Intermittent rough idle, limp home mode Stock 2002 - 2005 Explorers 2
L Trans problem 300 miles away from home Stock 2002 - 2005 Explorers 7
T I really need some input on limp home mode. Stock 2002 - 2005 Explorers 5
S 04 SportTrac is home, had abs 4 2 code. Stock 2002 - 2005 Explorers 0
K Explorer 2004 v8 4.6L, limited, transmission flush Stock 2002 - 2005 Explorers 3
T Unresponsive Transmission Stock 2002 - 2005 Explorers 7
M Mercury mountaineer transmission a Stock 2002 - 2005 Explorers 12
A Transmission question Stock 2002 - 2005 Explorers 2
B Transmission Pan Nut Stock 2002 - 2005 Explorers 1
M Transmission 2004 XLT 4x4 WTF? Stock 2002 - 2005 Explorers 2
D Transmission issue? Stock 2002 - 2005 Explorers 8
D Transmission leak in front Stock 2002 - 2005 Explorers 4
S Will 2000 fit 2002 transmission explorer Stock 2002 - 2005 Explorers 1
J 0w20 in transmission? Stock 2002 - 2005 Explorers 9
M transmission wiring harness 2005 explorer xlt 4.0l 4x4 Stock 2002 - 2005 Explorers 0
J Transmission clunk(metal on metal) when when first shifting from 1st into 2nd gear Stock 2002 - 2005 Explorers 16
J Transmission swap Stock 2002 - 2005 Explorers 2
S Transmission issue Stock 2002 - 2005 Explorers 3
A Advice on Transmission, possible failure - 2003 Explorer 4.6 L V8 Stock 2002 - 2005 Explorers 12
S Transmission Help Stock 2002 - 2005 Explorers 2
G Transmission died Stock 2002 - 2005 Explorers 9
A 15w40 instead of transmission fluid? Stock 2002 - 2005 Explorers 13
J Transmission Stock 2002 - 2005 Explorers 1
M Dreaded Transmission Questions... Stock 2002 - 2005 Explorers 3
D RSC transmission option questions Stock 2002 - 2005 Explorers 1
M Transmission leaking with photos Stock 2002 - 2005 Explorers 12
Stvincnt Found this Transmission guy What's that catch Stock 2002 - 2005 Explorers 8
Stvincnt What are these yummy Transmission boogers 2004 xls Stock 2002 - 2005 Explorers 2
H Testing normal transmission behavior ? Stock 2002 - 2005 Explorers 7
H Transmission Stock 2002 - 2005 Explorers 2
T Solved Fuel pump power issues after transmission swap. Stock 2002 - 2005 Explorers 5
H SR55W transmission Stock 2002 - 2005 Explorers 2
L 5r55w transmission trouble Stock 2002 - 2005 Explorers 1
L 2004 Ford Explorer xlt 5r55s transmission issues Stock 2002 - 2005 Explorers 1
E explorer 2005 aut transmission Stock 2002 - 2005 Explorers 0
P Transmission 1st to 2nd harsh upshifting Stock 2002 - 2005 Explorers 1
S Harsh knocking noise from back of engine or front of transmission... Stock 2002 - 2005 Explorers 13
W swapping a 2004 explorer transmission in a 2003 Stock 2002 - 2005 Explorers 2
B Procedure for adding transmission fluid? Link or Advice? Stock 2002 - 2005 Explorers 10
I Transmission problems (kinda) Stock 2002 - 2005 Explorers 0
L Transmission Additive Stock 2002 - 2005 Explorers 5
MartyD Need a New Transmission Stock 2002 - 2005 Explorers 5
J Transmission slip 2005 Explorer Stock 2002 - 2005 Explorers 15
T Oil pan or transmission aka Uhhh yeah this just happened Stock 2002 - 2005 Explorers 16
I Transmission swap ideas? Stock 2002 - 2005 Explorers 23
R Transmission Breather Loose? Stock 2002 - 2005 Explorers 0
M 2005 Intermittent transmission issues Stock 2002 - 2005 Explorers 4
L Transmission Failure Stock 2002 - 2005 Explorers 0
Similar threads
