Aviad
- November 20, 2022
- Israel
- 2013 Explorer XLT
Hello,
I have 2013 Explorer XLT, couple of days ago suddenly I get an error massage on the left screen: "Terrain management system fault".
In addition, the terrain selection knub indicator light is off (no red light on).
No other error massages, not MIL light on, no wrench light.
Car drive excellent, no issues. Only the "Terrain management system fault" massage keeps popping.
I scanned for error codes using Forscan and got the following code in the ATCM module:
ATCM U3000:49-0a
Code: U3000 - control module
additional fault symptoms:
- internal electronic failure
Sometimes I get also additional ATCM error code:
ATCM C1A02:23
Code: C1A02 - rotary encoder stuck in intermediate position
- signal stuck low
When I try to clear the DTC codes, the ATCM U3000:49 stays and ATCM C1A02:23 is cleared.
I will just that the decent hill function works, the button is shared with the terrain selection knub.
I tried to reset the ATCM module using Forscan and the code is not clearing.
I disconnected the battery, trying to reset the ATCM module with no success.
I feel like it related to electric signal that doesn't passthrough correctly, due to back connector of electricity issue.
I'll appreciate the forum assistance to try to solve this issue/.
if someone encountered similar problem? or there is a way to discharge the module?
ATCM U3000:49-0a
ATCM C1A02:23
- signal stuck low
