MrPulldown
- March 1, 2017
- Truckeee
- 2004, 4wd, 4.6l
Did a drain and fill, along with a pan drop and filter change. Fluid was pretty dark and gunky. I did a drain and fill about 20K ago. Filled it with 4 quarts of Supertech Merc V and about 1.5 quarts of Maxlife. Though maxlife does not specifically state that it is Mercon V compatible, there has been a lot of documentation on this site that it works fine. I was a little short and did not want to run to the store; I had a jug of maxlife ATF on hand.
My Father in Law must have done a pan drop at some point. Aside from a little grim on the magnet and filter body things were pretty clean. I think the filter was aftermarket too as it was not a motorcraft branded part. Installed a WIX filter and cleaned the magnet. That reusable OE gasket sure is nice. Not sure why WIX included that POS rubber gasket.
I did have something that were a little weird. Ran the engine for 15 min or so and the tranny pan barely got warm. Did get a 85 degree reading off the pan so I figure that was warm enough. I let the ATF dripple out of the center drain tube hole with the transmission in P. I noticed that with the tranny in gear (R or any of the Ds) that the fluid stopped coming out of the drain hole. I suppose this is normal. Or should I be setting the fill level with the tranny in gear? I think most of the write up's say to do so in PARK.
The front diff oil was the only oil that I had not touched since taking possession of this car about 20K miles ago (now at 140K). Part of the reason was the fact that there is no drain plug and I did not want to go through to diff cover removal. Instead I was able to pull a siphon, and get the gear oil out. THat was some dirty fluid with silver streaks. Kind of wanted to pull the cover jsut to inspect and clean. Filled it with a mix of 75-90 and 80-90 w syn and conventional. What is the difference between the 2 weight gear oils (other than the 5w). Both are GL5. Does't seem like they should even have the 2 different weight oils. Am I missing something?
