halfbakedj14
- April 13, 2010
- 96 explorer
After reading various posts here I attempted to fix my blend door. I was only able to have heat, nothing in between or cold air just heat. I cut a square out of the heater core and looked inside and the blend door actually looks like it is fine, it swings freely just fine and doesn't appear to be broken but I' no expert. The Actuator on top didn't move when I cycled through different temperatures so I think that might be my problem but I also noticed that when I moved the position of the blend door that the air temp did get a little cooler but not as cold as it should, would this be a freeon issue or related to the actuator?
