Mtn8er
- August 5, 2006
- Portland, OR
- 98' Mountaineer 5.0
Well I'm getting ready to do some tranny work and just got done ordering my Baumann valve body kit. I already have 20 quarts of Amsoil ATF as well for when I get done installing it I will be doing a full system flush as well. Anyways, I want to get a new transmission pan to install with it all (a nice one that holds a few more quarts and has a drain plug) along with a transmission temp. gauge.
My question is, some of the transmission pans that I have been looking at have the option or already have a 1/8 NPT temperature sender port in the pan. Is this port for a mechanical gauge only or electrical? I understand you will get a more accurate transmission temp. reading by having the sender in the actual pan rather than putting a "T" up front in the transmission cooler line. So far I'm looking at the Mag-Hytec, PML, or Ford Racing pans.
Also, because these pans hold more fluid and are deeper will a stock transmission filter work or do you have to get some sort of filter extension? Anyone who has any of this stuff, let me know.
