jakegator
- August 1, 2012
- PA, USA
- 1998 explorer 4dr ohv
Hello, so i currently have a 92 explorer 306000 miles original auto. Well i hate autos and mines about shot so im putting in a manual. Im currently in the process of getting the parts together. I have the manual trans, which has the slave cylinder attached, clutch, pressure plate flywheel.
so here are my questions.
1. the slave cylinder was never removed however the throw out bearing has some surface rust and at the very least needs greased. The slave cylinder looks new and the guy i got it from said it was new. Do I need to replace it (the slave cylinder)since it was never removed from the trans? I know its recommend when they are removed? also does the throw out bearing need replaced?
2. the guy also said the clutch and pressure plate is new (not as new as the slave). they are both rusty and best i can tell is surface rust. Is it ok if these are a little rusty?
3. finally the flywheel is rusted but looks defective free, all of this is from the same explorer, should i resurface it r not worry about it?
Thanks in advanced!
Thanks in advanced!
