The_Commodore
- April 4, 2006
- Raleigh
- 91 XLT
I finally got my new engine running on my 91, but now the auto transmission does not want to shift on its own. I pulled the torque converter out with the old engine, but that and the input shaft on the trans did not appear to be damaged, and everything went back together fine. The check engine light is on, turns off when you change between park, reverse, and drive, but turns back on after a minute. Im afraid I may have internally damaged the torque converter, but I can shift between 1st and 2nd manually on the column shifter. Thats the only way I can get it to shift gears in drive, I cant get it to shift automatically. Is it the torque converter, or hopefully something easier and less expensive to repair?
