TechFreak
- September 28, 2015
- 2015 Explorer Limited
Just curious if anyone else has this or knows if something can be done to remedy this. It hit 97 degrees today and I jumped in my 2015 Explorer Limited with Black Interior which was facing the sun (Needless to say it was pretty warm in there). I always have it set to 'Auto' for the Climate control with the temperature set to 72 degrees. The A/C kicked in and the fans were going but I noticed that it didn't seem like they were running at full speed. I clicked the + on the fan speed and the fan increased. The fan appears to only run at 3/4 the max fan speed when set to Auto. If I select 'Max A/C' the fans run at 100% and Temperature shows 'LO'. In some further testing I set it back to Auto. The fan speed dropped to 3/4 again. I then lowered the cabin temperature one degree at a time. When I dropped it down to 68 degrees the fan speed then was running at 100%. I believe at 69 or 70 degrees you could hear the speed increase but it was not at 100%. Is it just me or shouldn't the fans run at full speed initially to reduce the cabin temperature down as quickly as possible? I know in the winter the fan speed starts off low until the engine warms up then it goes to 100%.
