Frolin
- June 5, 2003
- San Antonio, Texas
- 2013 Limited
Adding a front push bumper and off-road Driving Lights to my 2013 Explorer Limited, and wondering what others have done for a toggle switch setup and location ?
Went to an XLT, came home with Limited with extras. The 3-button setup on left is all used up. It's been 'away from home' for a bit so can't go look at the dash at present. It's a classy model so don't want a cheap toggle switch drilled and mounted. So wondering about options.
A- any other stock places maybe I have not noticed to add a simple switch ?
B- wiring, any thoughts / benefits to having a 3-way to select when they come on as... highbeam-off-on. So link to high beams or just turn on, vs simply link to high beams ?
C- suggestions for wiring as plan to put the switch on/under the console area, and the lighting harness relay under the hood, where is an easy place to tap in to the high beam power line to get power signal for the aux lights relay ?
thanks!
Frolin
thanks!
Frolin
