ponkotsu
- October 29, 2012
- Colorado Springs, CO
- 2005 Lincoln Aviator
When I say rough, I don't mean terrible. Once it's good and warmed up it idles pretty smooth at 600RPM. Seems to hunt once in a while. Cold idle is a little rough. Sometimes when accelerating from a stop it has a very slight stumble/miss until it gets over 1500rpm. I think the average motorist wouldn't even notice.
It's got new plugs and boots. New air cleaner. I verified all the coils have correct resistance so are probably good. Cleaned the MAF sensor, IAC and EGR. PCV is good. No noticeable vacuum leaks under the hood. Fuel economy seems to be okay for the vehicle. (12 city 20hiway). Runs smooth. Goes through only about 1/2 qt of oil in 6k miles, so not bad for 150k. I've run a couple different quality fuel system cleaners through the tank with no effect. Other than the slightly rough idle, it runs and drives like new. I've never had any engine codes.
I heard Explorers have a plastic intake, but I believe the Aviator has an aluminum with 8 individual throttle plates.
Short of pulling off the intake and cleaning, does anyone have any suggestions? This is definitely not bad enough to warrant pulling the intake because that seems like a pretty intense job on an Aviator. The engine has 150k on it, so maybe that's just as good as it will get?
