Aviator- Turn signals not stopping blinking
Aviator and the Z
Ventura
2020 Aviator
Our Aviator (purchased beginning of Sept.) will not stop blinking after making turns. We took it to the Dealer, and they said they have to replace the whole steering column. Does this seem normal?
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve II
Callsign
VE3
Since you are the first to report the issue, there are no other posts to refute what the dealer said. The way everything is integrated these days, it wouldn't be surprising.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
They wouldn’t replace that column unless they had to.
northvibe
2020 Ford Explorer XLT
odd. Although I JUST read about this config setting in forscan. You can set your blinker to blink and stay blinking even after the stalk clicks back to the middle. Could just be a config change. Otherwise there could be more wrong with the blinker stalk.
EDIT: I found this info when looking to make changes to the number of blinks, that happen when you tap the blinker for a lane change.
