smcmoran
- March 14, 2011
- Medford, NJ
- 2000 Explorer Limited
I have a 2000 explorer limited with V8, AWD and limited slip read. It has the shackle, add a leaf and TT lift with 31's. After recently getting stuck and seeing how poor the Viscous coupled transfer case can be in s tricky situation, I started thinking about swaping for an automatic shift 4wd, 4405 transfer case. The wiring appears to be in the harness and there are a few of those cases available.
When I search here I get all the 4406 manual shift swaps. Not sure I want to go to that yet. I was curious if anyone has swapped to the 4405 and wired in the 4wd switch? How does it work and is it worth it?
Thanks
Scott
Thanks
Scott
