JakePSD
- March 25, 2010
- Ohio
- 2003 Mercury Mountaineer
The transfer case on my girlfriends 97 AWD V8 Mountaineer is making some God awful noise. I just put a new (junkyard) front drive shaft in the truck since it didn't have one when we bought it, and I noticed as I was tightening the bolts at the Tcase end the flange would slip and pop when I put a decent amount of torque on the wrench. I knew then something wasn't right but I proceeded to finish putting it on anyway just to see what would happen. As I pull out of my driveway, which is covered with snow, when the rear wheels begin to slip there is some loud popping/grinding sounds coming from the transfer case. Even making a turn causes it since obviously the front and rear wheels are spinning at different speeds.
What do you guys think is wrong inside it? Is the transfer case on these rebuildable? If so, is it something a good DIY mechanic can do? I've torn apart regular 4x4 tcases and they worked when I put them back together. If this isn't rebuildable, how much do they usually run and does anyone on here have one for sale?
I now realize why that son of a ***** didn't have the front d-shaft on it when he sold it.
