X6StringerX
- June 19, 2006
- 2011 Lincoln MKS EcoBoost
I was previously under the impression that both the 4.0 4WD Explorers and the 5.0 AWD Explorers utilize the same hub assembly, but while doing some price research, I've run across a few part numbers that specifically note that they are for one or the other, but none of them say both.
I actually don't even need hub assemblies, but I'm having a low speed ABS issue and the rear sensor has already been replaced. Rather than spend $90 on the new front sensor by itself, I can spend $100 and get a new hub assembly with a sensor included. However, the hub assembly that is priced at $100 is one of the ones that specifically notes that it is for a 4WD. The one that says AWD is $170. If there is, in fact, a difference, then I'll just buy the sensor by itself and save $80.
