Axle Widths?
Clutch1819
Tuskegee,Alabama
91 EB
Whats the width of a dana 30 and dana 44 from a jeep wrangler? Is it around the same as the dana35 IFS thats under a 91 Explorer? I have found an axle for an SAS swap but i need the info. thanks.
Clutch1819
Tuskegee,Alabama
91 EB
Alright. Found the info i was lookin for. But one other thing. On a front SA leaf spring setup does it matter which end the shackles are on? ive seen them in front of the front tires and behind.
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
There's arguments supporting both.
Shackle to the rear will track better and generally drive better on the street. This also puts a solid mount at the front that can be easier to slide over obsticles. Down side is the driveshaft length needs to be dead on and it needs lots of slip built in to compensate for the fact that the housing will move forward on downward travel.
Shackle at the front will pull the housing back as it droops, thus compensating for driveshaft slip- this means you can get alot of suspension travel without much driveshaft travel and pinion change. Downside is you (might) have shackles hanging down that get hung up on occasion and generally more foul street manners.
Pick your poison.
