B-pillar issue | Ford Explorer - Ford Ranger Forums - Serious Explorations
B-pillar issue
clayjo
Norwalk, CT
2013 Explorer Sport
Is it easy to replace the b-pillar black plastic covers?
Long story, but can someone please confirm how they are attached. Need to replace mine. both the driver's side door and its' rear doro counterpart.
Thanks!
Believe it's part numbers:
20554
255A34
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Thanks!
20554
255A34
Those appear to be the correct part numbers. I don't recall any posts by a member that has replaced them. If you don't get an answer to the question, I would suggest calling the dealer parts department and ask them. You will likely have to contact them anyway to order the parts.
I assume this isn't a warranty issue.
Good luck.
Dr Plastic
Newport News, Virginia
'15 Limited FWD
Pull off the inner door edge mouldings and they just snap on/off. Just be careful of the airbags!
Kpwweb
Springfield, MO
2013 Ford Explorer Sport
I need this as well... Slammed the door on my finger when the ex was BRAND NEW! Needless to say it broke the driver's side b-pillar moulding and took a big chunk out of my finger!
I found out that the numbers for entry code keypad are built into the trim--bummer and expensive!
But what do you mean by "inner door edge moulding"? Could you please clarify?
Also I assume that some wiring harness will have to be un-clipped and re-clipped? Does the inner door panel need to be removed?
Thanks!
Dr Plastic
'15 Limited FWD
I apologize I mistakenly thought you wanted to remove the interior mouldings.
peterk9
Staff member
Moderator
Callsign
VE3
Well I must admit after a trip to the garage this morning to check out your initial response I too was left scratching my head. :scratch:
Most of us all make mistakes now and then so no big deal. I believe we are allowed one a month so be careful. :D:thumbsup:
peterk9
Staff member
Moderator
Callsign
VE3
Thanks!
Have you checked with your dealer to see what they would charge to order and replace the parts? The thing I might be concerned about is the keypad. If you do the work and the keypad malfunctions down the road they may try to deny any warranty coverage. Just something to keep in mind.
mattrasche
2013 Ford Explorer
Any luck?
Did you ever attempt to do this? I am considering replacing my pillar with the keypad as it no longer works.
Kpwweb
Springfield, MO
Not yet. I have the pillar. Just need the time!
The keypad is part of the pillar--so not a big deal. It looks fairly easy to remove, just the adhesive looks a little "stricky".
mattrasche
2013 Ford Explorer
Thanks. If I get around to it first I'll reply how it went.
SixPonies
Mahomet, IL
2017 Ford Explorer Sport
Please do. My door keypad no longer consistently functions properly, and I'm out of warranty. So I'm considering replacing it myself, but unsure of whether or not this is a DIY job, or if it needs to be done by the dealership techs.
Stick4503
Winder, Georgia
1996 & 2004Explorer 4x4
My link may be broke. My phone is dying will fix link shortly.
mattrasche
2013 Ford Explorer
OK, so I replaced the keypad B-pillar...and it still doesn't work right. Any ideas on that? It still only works intermittently, but appears to very consistently light up and work from the standpoint now.
I basically just started to peel off the pillar from the top down and then attempted to slide fishing line behind it to release the adhesive, but didn't work too well. So I just continued to peel, and then it started cracking into pieces. I just worked my way down cracking it apart basically since I was throwing it away. I had to take the inner door panel off to get to the wiring, see link (http://www.paulstravelpictures.com/Ford-Explorer-Interior-Door-Panel-Removal-Guide/). Easiest way to get to the plug was through the door lock hole on the metal frame. Frustrating.
KBL2202
Peoria, IL
2013 Explorer XLT - 2.0T
So if i was going to replace the passenger side, I wouldnt need to take the inner door panel off?
mattrasche
2013 Ford Explorer
No, I wouldn't see a need to take inner door panel off as that was only to get to wiring.
ThomasEason
Garner, NC
2014 Explorer Sport
Hello, First time on here.
My 2014 Explorer Sport has the outer door panel on the passenger side door starting to come off....not the front A-frame(?), but the one on the side of the door. There is one just like it on the front of the back doors. It's like the glue is giving out. I was just going to buy some automotive adhesive, but surely this is a common thing. I'm way out of warranty, but does anyone know of a recall on this?
If I drive much more, it will end up on the side of the road, then I'm sunk.
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum.:wave:
The issue of the inner door panel has a Customer Satisfaction Program for it and discussed on page 6. Is your issue with the sheet metal? If it is different than the pictures shown in the thread, a photo would be helpful to show exactly what the problem is.
ThomasEason
Garner, NC
2014 Explorer Sport
Thanks for the response! It's not the inner panel, but the outer trim that's giving me problems. Photos attached.
