Back in a Ford Explorer after years away!
mattadams
Moderator Emeritus
Longmont, CO
2017 Explorer Sport
Doubt most folks around here even remember me anymore... but used to be quite active in the early days of the forum when I had a lifted 94 Explorer with all kinds of lights on it. I used to be moderator of the performance lighting forum, and I've been moderator of the escape forum for several years, but that forum doesn't get much activity here, but still kept me popping in from time to time. Otherwise, I've been fairly dormant. I've had a Ford Escape since 2011 or so, and it was just stock and had no major problems.
Thursday I flew out to Ohio and picked up a 2017 Ford Explorer Sport and drove it back to Colorado Thursday and Friday. We're finally back home!
Not a whole lot in the way of plans to modify it... specifically tried to find an explorer with most everything I wanted so I wouldn't HAVE to modify anything. Planning on some weathertech floormats, other than that, not much!
So far the only problem I've found with the explorer is that locking the front door my touching hte handle seems to work intermittently at best... not sure if that's a common problem, but not a major deal. I did figure out how to get my keypad code (the dealer I bought it from wasn't a ford dealer and couldn't seem to figure out how to do it) and one of the keys is damaged and held together by tape, but I was originally told it only had one key, so I'm not too upset over that. Will likely have to replace it soon, but was planning on that expense...
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome back Matt and welcome to the 5th gen Forum.:wave:
SBK_
San Jose, CA
2018 Base Explorer
Once Explorer, Always Explorer !
bigtexan99
2016 Explorer Sport
Excellent choice!
If you have 2 working keys, you can buy spares on ebay pretty cheap and program them yourself.
mattadams
Moderator Emeritus
Longmont, CO
2017 Explorer Sport
Excellent choice!
Thanks, I'd looked into that! I'd heard different things about whether keys could be programmed, but for what I imagine the dealer will charge me for it, it is probably worth it to at least try...
A Ford Explorer 2011-2013 Power Steering Failure Stock 2011 - 2019 Ford Explorer Discussion 1
M 2018 Ford Explorer Sport buzzing sound Stock 2011 - 2019 Ford Explorer Discussion 2
J Ford Explorer Tow Capacity Stock 2011 - 2019 Ford Explorer Discussion 4
T 2017 Ford Explorer - Exterior trim pieces in horrible shape Stock 2011 - 2019 Ford Explorer Discussion 2
W 2013 Ford Explorer Struggles to crank Stock 2011 - 2019 Ford Explorer Discussion 5
S New member here! First time Explorer owner, Ford person. Having an issue... Stock 2011 - 2019 Ford Explorer Discussion 6
J 2013 Ford Explorer electric issue Stock 2011 - 2019 Ford Explorer Discussion 6
T 2013 Ford Explorer Sport Whistling during acceleration Stock 2011 - 2019 Ford Explorer Discussion 0
D 2016 Ford Explorer trans slips colder temps Stock 2011 - 2019 Ford Explorer Discussion 6
J 2018 Ford Explorer Lift Gate Stock 2011 - 2019 Ford Explorer Discussion 1
D 13 Ford Explorer Light Module Location Stock 2011 - 2019 Ford Explorer Discussion 3
A 2012 Ford Explorer XLT Front Suspension Clunking Noise Stock 2011 - 2019 Ford Explorer Discussion 17
L 2012 Ford Explorer Ambient Lighting Wiring Stock 2011 - 2019 Ford Explorer Discussion 3
J How to replace a rear broken stud 2016 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Ford Explorer - Timing Problem Stock 2011 - 2019 Ford Explorer Discussion 9
A 2016 Ford Explorer rattle Stock 2011 - 2019 Ford Explorer Discussion 8
P 2017 Ford Explorer Limited drivers side LED fog light has quit working Stock 2011 - 2019 Ford Explorer Discussion 2
J Looking at a 2016 Ford Explorer XLT 3.5L Stock 2011 - 2019 Ford Explorer Discussion 16
G 2012 Ford Explorer blower motor resistor Stock 2011 - 2019 Ford Explorer Discussion 4
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
J 2018 Ford Explorer XLT horn issue Stock 2011 - 2019 Ford Explorer Discussion 4
C 2015 Ford Explorer Keeps blowing interior light #12 fuse. Stock 2011 - 2019 Ford Explorer Discussion 2
D About to join the Ford Explorer Sport family.. Stock 2011 - 2019 Ford Explorer Discussion 7
R 2018 Ford Explorer Sport electrical issues Stock 2011 - 2019 Ford Explorer Discussion 2
D Gas Additive for Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 6
M 2013 Ford Explorer Dash Noise\Grinding-Not a blend door I think Stock 2011 - 2019 Ford Explorer Discussion 3
O 2012 Ford Explorer ignition lock reset Stock 2011 - 2019 Ford Explorer Discussion 3
G $$$ Dollar Value of 2017 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 5
P 2015 Ford Explorer Limited stalling at intersections/idle Stock 2011 - 2019 Ford Explorer Discussion 4
N Ford Explorer 2016 AC not working grey out Stock 2011 - 2019 Ford Explorer Discussion 10
G 2013 Ford Explorer XLT Rear camera replacement Stock 2011 - 2019 Ford Explorer Discussion 13
D 2017 Ford Explorer Sport stock exhaust Stock 2011 - 2019 Ford Explorer Discussion 10
E Comparisons between 2014-2015 models vs 2016 and up Ford Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 20
J 2018 Ford Explorer XLT outlets Stock 2011 - 2019 Ford Explorer Discussion 2
P 2016 Ford Explorer Sport brake job Stock 2011 - 2019 Ford Explorer Discussion 0
W 2018 Ford Explorer Damaged Front Camera Stock 2011 - 2019 Ford Explorer Discussion 6
H 2016 Ford Explorer Limited Speaker and Amp Upgrade - Help Sought Stock 2011 - 2019 Ford Explorer Discussion 1
H Help - 2016 Ford Explorer Limited - Won't Start Stock 2011 - 2019 Ford Explorer Discussion 3
J 2018 Ford Explorer RPM gauge not working Stock 2011 - 2019 Ford Explorer Discussion 8
J 2018 Ford Explorer LED bulbs Stock 2011 - 2019 Ford Explorer Discussion 9
S 2013 Ford Explorer driver seat doesn’t recline back Stock 2011 - 2019 Ford Explorer Discussion 4
J 2012 Ford explorer limited damages repairs Stock 2011 - 2019 Ford Explorer Discussion 8
S 2019 Ford Explorer Sport Questions Stock 2011 - 2019 Ford Explorer Discussion 19
J 2015 Ford Explorer Sport BCM Issue Stock 2011 - 2019 Ford Explorer Discussion 12
J 2018 Ford Explorer XLT White Platinum Sport Appearance Package mods Stock 2011 - 2019 Ford Explorer Discussion 12
R Front strut replacement 2013 Ford Explorer Stock 2011 - 2019 Ford Explorer Discussion 4
L 2016 Ford Explorer PTU Drain Plug Size Stock 2011 - 2019 Ford Explorer Discussion 7
L 2020 Ford Explorer spied barely disguised in civilian spec Stock 2011 - 2019 Ford Explorer Discussion 1
S 2016 Ford Explorer 2nd Row Bucket Seats Stock 2011 - 2019 Ford Explorer Discussion 8
Similar threads
