Back up alarm
Dave Austin
Hinsdale, NH
2003 Limited V8
Sorry i couldn't find where to post this. When in park my backup alarm has no light on but when I shift to reverse the light comes on and the alarm says off. I would think the alarm would be on if the light was on.
Anyway, I have only had the vehicle ( 2003 Explorer Limited V8) a very short time but I thought I remembered the alarm working when i first got it. I have had a Kenwood receiver with a backup camera installed since purchase, could this installation be the reason alarm is not working now?
03Explo20
2003 Explorer XLT
I think you may have a bad sensor in the bumper or, like you said, the receiver install could have something to do with it.
If it is a sensor, you can get a whole set on eBay for about $30 and just change them all out.
R Code alarm won't crank. Light blinks twice. Stock 2002 - 2005 Explorers 0
T Car Alarm Keeps Going Off Stock 2002 - 2005 Explorers 2
Z New to FE - Alarm Issue Stock 2002 - 2005 Explorers 2
T I am trying to reset the alarm system for a 04 Ford Explorer, Pls help. Stock 2002 - 2005 Explorers 0
K factory alarm going off while charging battery Stock 2002 - 2005 Explorers 3
A Alarm killed car? Stock 2002 - 2005 Explorers 8
B 02 Explorer\relay\ford factory alarm Stock 2002 - 2005 Explorers 5
T Alarm going off every time I unlock the door… Stock 2002 - 2005 Explorers 2
B 2002 Alarm System help Stock 2002 - 2005 Explorers 2
C 2004 Explorer Alarm Stock 2002 - 2005 Explorers 17
M 2005 Eddie Bauer alarm system Stock 2002 - 2005 Explorers 1
S Sticky driver's door lock...alarm goes off. Stock 2002 - 2005 Explorers 27
G BATTERY DRAIN-CAR ALARM GOES OFF/INTERIOR LIGHTS STAY ON Stock 2002 - 2005 Explorers 2
W Security alarm, auto unlock, parking lights, door ajar, oh my! Stock 2002 - 2005 Explorers 15
S Alarm went off last night Stock 2002 - 2005 Explorers 0
I Panic alarm randomly tripped Stock 2002 - 2005 Explorers 18
Q Accessory power comes on after arming alarm with key fob Stock 2002 - 2005 Explorers 2
T 2002 Explorer Alarm Issues Stock 2002 - 2005 Explorers 2
T 2002 Alarm going off Stock 2002 - 2005 Explorers 0
T Ordered a Alarm Stock 2002 - 2005 Explorers 6
D Alarm Stock 2002 - 2005 Explorers 4
M Door ajar light stays on and alarm won't go off... Stock 2002 - 2005 Explorers 8
T How Do I Go About Adding a Factory Alarm? Stock 2002 - 2005 Explorers 1
R Door Ajar Alarm Stock 2002 - 2005 Explorers 1
M Car Alarm Issue Stock 2002 - 2005 Explorers 1
J Alarm goes off constantly Stock 2002 - 2005 Explorers 2
H Intermittent alarm fiasco, child locks? Stock 2002 - 2005 Explorers 0
S Another Alarm Goes Off Randomly Thread Stock 2002 - 2005 Explorers 2
H Horn, Lights Go Into Alarm At Random Times Stock 2002 - 2005 Explorers 3
P radio/lift gate glass/fuel level/alarm problems Stock 2002 - 2005 Explorers 3
D PATS/Aftermarket alarm/remote start? Stock 2002 - 2005 Explorers 3
E 2005 Eddie Bauer alarm and interior lights Stock 2002 - 2005 Explorers 2
S Alarm Goes Off at Turn of the Ignition Stock 2002 - 2005 Explorers 2
K 2002 Ford Explorer Door Ajar Alarm Stock 2002 - 2005 Explorers 3
N 2002 Explorer Panic Alarm Randomly Firing Stock 2002 - 2005 Explorers 0
R Backup Alarm Volume Stock 2002 - 2005 Explorers 3
A 5x5 SRS alarm Stock 2002 - 2005 Explorers 0
B Anti-theft alarm problem, Ford Explorer 2003 Stock 2002 - 2005 Explorers 6
F Explorer keyless entry and alarm issue Stock 2002 - 2005 Explorers 1
P 05 XLT Dome Light Stay On, No Door Open Alarm Stock 2002 - 2005 Explorers 1
N Alarming issue with my alarm... Stock 2002 - 2005 Explorers 1
J Driver belt and alarm Stock 2002 - 2005 Explorers 5
P Low Oil Pressure Alarm with inconsistent gauge Stock 2002 - 2005 Explorers 3
U Power Code Alarm - yep, another one. Stock 2002 - 2005 Explorers 0
J noisy alarm Stock 2002 - 2005 Explorers 1
T 2005 Explorer alarm install...STUCK? Stock 2002 - 2005 Explorers 1
C 2002 Explorer- major alarm issues Stock 2002 - 2005 Explorers 4
K 2002 Explorer NO START (Alarm issue maybe?) Stock 2002 - 2005 Explorers 3
F Alarm Stock 2002 - 2005 Explorers 1
J Chime / Alarm Location? Stock 2002 - 2005 Explorers 21
Similar threads
