My 120K mile 1993 Ford Explorer acted up this morning. I started it normally but right as I released the key, I heard a 'bpooff' sound and it quit running. It seemed like a backfire at first and I could smell unburned fuel. I tried to start it again and it started but ran at 2700-2900 RPM for about a second and a half and then stopped. I thought a sensor or something may have sent a wrong signal to the computer, so I took the battery cable loose to reset the computer and then tried it again. Same result, running fast only for a short period. I gave it some gas as it went to stall and it seemed to run roughly for a bit but I was concerned there may be something wrong with the timing chain or something of that nature so I promptly quit giving it gas and let it die.
I bought this vehicle new and have maintained it flawlessly for its whole life. The only real problem (besides the damn brake wear) has been the thermostat I replaced last summer. Also last summer I replaced the entire airbox with a high flow filter unit similar to a K&N type.
I was thinking it the timing chain may have slipped a tooth or something similar since the way it is now running, it seems it is either the timing or perhaps something to do with a damaged sensor from the ?backfire? I may have let go of the key too quick when I was first starting it which may have caused the "backfire". Its never "backfired" before and it was running perfectly last night when I parked it.
Any advice somebody can provide me would be greatly appreciated. I have a young special needs child who requires most of our limited resources and will have to perform any needed repairs myself.
Thanks,
Mark C. Mink
mailto:mmink@prestonphillips.com
Phone: (770) 396-8752 Direct: (770) 396-1144 x217
Fax: (770) 396-4767
All who wander are not lost!
Mark '93 Sport
Thanks,
Mark C. Mink
Fax: (770) 396-4767
Mark '93 Sport
