Backup Camera Location
t4rest
Mabank, TX
2011 Ltd
Does anyone know the location of the backup camera? Is it up high around the center high stop light or is it low close to the license plate? The reason is "WHEN" is get my Ex, I'll be heading out for a long vacation and I'm concerned that there my not be enough room for the whole family(5) and everything else. The two options are a roof mounted storage, Thule, or one connected to the trailer hitch. The roof mounted storage has the problem of lifting the bags to the roof, very awkward. The hitch mounted one may block the backup camera. The dealer here in the East Texas Sticks does not have an Ex to look at, so I need some help with the decision.
1995E
Maryland
95 + 11 Ex both XLT
The backup camera is located above the license plate below the Explorer chrome trim.
t4rest
Mabank, TX
2011 Ltd
Thanks
JustB_Rad
Milwaukee WI
2011 Explorer XLT
I had 10 bags of mulch on my hitch rack last weekend...so stacked about 36", and my camera was still usable. Obviously not as great as with nothing, but still useful. Also, the roof only has a 100lb capacity, and most racks have a 500lb capacity.
R Liftgate backup camera trim/housing with washer part numbers Stock 2011 - 2019 Ford Explorer Discussion 3
N Adding the "turning" lines to the backup camera. Stock 2011 - 2019 Ford Explorer Discussion 7
J Backup Camera Guidelines No Longer Present Stock 2011 - 2019 Ford Explorer Discussion 11
D Backup Camera guidelines keep falling off after being restored with Forscan Stock 2011 - 2019 Ford Explorer Discussion 0
D Can the backup camera cover be replaced? Stock 2011 - 2019 Ford Explorer Discussion 11
M Backup Camera For a 2013 Base Model Explorer Stock 2011 - 2019 Ford Explorer Discussion 1
R Cloudy backup camera Stock 2011 - 2019 Ford Explorer Discussion 5
F Backup camera lines Stock 2011 - 2019 Ford Explorer Discussion 1
H apim replacement made backup camera not work as well Stock 2011 - 2019 Ford Explorer Discussion 31
P Backup Camera and Navigation Stock 2011 - 2019 Ford Explorer Discussion 4
D Backup camera Stock 2011 - 2019 Ford Explorer Discussion 4
2 Backup Camera Resolution Stock 2011 - 2019 Ford Explorer Discussion 36
R 2013 XLT Rear Bumper & Backup Sensor Stock 2011 - 2019 Ford Explorer Discussion 6
J Backup Blade Key Missing - No Original Stock 2011 - 2019 Ford Explorer Discussion 1
M 2012 Explorer Backup Sensor Stock 2011 - 2019 Ford Explorer Discussion 4
F 2013 Explorer Sport backup sensor issue Stock 2011 - 2019 Ford Explorer Discussion 3
A Backup Sensor Stock 2011 - 2019 Ford Explorer Discussion 4
K 2011 Explorer back up camera guidelines missing Stock 2011 - 2019 Ford Explorer Discussion 1
G need help with front assist parking camera Stock 2011 - 2019 Ford Explorer Discussion 1
B New member with camera problems Stock 2011 - 2019 Ford Explorer Discussion 8
G 2013 Ford Explorer XLT Rear camera replacement Stock 2011 - 2019 Ford Explorer Discussion 13
W 2018 Ford Explorer Damaged Front Camera Stock 2011 - 2019 Ford Explorer Discussion 6
R rear assist camera Pin-BB5T-1QG490-AC Stock 2011 - 2019 Ford Explorer Discussion 2
W Looking for 12+ and 12- constant power for camera Stock 2011 - 2019 Ford Explorer Discussion 12
R Front and rear camera washer. Stock 2011 - 2019 Ford Explorer Discussion 3
E Camera Washer Not Working Stock 2011 - 2019 Ford Explorer Discussion 31
T How to: 2017 Explorer - Replacing front camera Stock 2011 - 2019 Ford Explorer Discussion 23
W '17 Explorer - Front Camera Wide Angle Mode Stock 2011 - 2019 Ford Explorer Discussion 5
D Back up camera 2017 compatibility with 2013? Stock 2011 - 2019 Ford Explorer Discussion 2
Eltee Can I Add My Camera to a Non-camera Tailgate Trim Piece ? Stock 2011 - 2019 Ford Explorer Discussion 4
S License plate led camera interference Stock 2011 - 2019 Ford Explorer Discussion 11
E Front camera on XLT Stock 2011 - 2019 Ford Explorer Discussion 0
A Rearview Camera Stock 2011 - 2019 Ford Explorer Discussion 4
P Front Camera Stock 2011 - 2019 Ford Explorer Discussion 1
expoman55 2016 rear camera / washer housing Stock 2011 - 2019 Ford Explorer Discussion 3
P Busted Front Camera Stock 2011 - 2019 Ford Explorer Discussion 0
L 2016 sport front camera washer? Stock 2011 - 2019 Ford Explorer Discussion 9
M 2016 Explorer Sport Front Camera Washer Stock 2011 - 2019 Ford Explorer Discussion 2
cwescapexlt4x4 2016 Limited windshield with "camera" Stock 2011 - 2019 Ford Explorer Discussion 16
expoman55 2016 rear camera washer Stock 2011 - 2019 Ford Explorer Discussion 15
C 2013 Explorer Rear Camera Stock 2011 - 2019 Ford Explorer Discussion 2
K Rear camera sound Stock 2011 - 2019 Ford Explorer Discussion 3
K Back up camera/warning worth its weight in gold! Stock 2011 - 2019 Ford Explorer Discussion 26
L Back up camera question Stock 2011 - 2019 Ford Explorer Discussion 29
H Rear camera and beepers Stock 2011 - 2019 Ford Explorer Discussion 9
R Uh Oh! Back up Camera shows bumper!! Stock 2011 - 2019 Ford Explorer Discussion 14
G Rearview camera? Stock 2011 - 2019 Ford Explorer Discussion 8
B Towing Package with Rear Back up Camera Stock 2011 - 2019 Ford Explorer Discussion 15
BobbyMarks Rear Video Camera Wiring Protective Cap Stock 2011 - 2019 Ford Explorer Discussion 9
M New Owner, Couple Quick Towing / Camera Questions Stock 2011 - 2019 Ford Explorer Discussion 16
Similar threads
