Bad abs sensor....
hockeyadc
NJ
2002 Ford Explorer
Can you replace just the abs sensor in a wheel hub? I replaces the hub assembly months ago and now I have an abs light again and when I scanned the car its the same front left hub. I think advance auto sold me a crappy sensor/hub assembly but its too late now to take it back...
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
Could still be a/the bearing. Sensors are almost as much as bearings. Have you checked to see if they'd warranty it?
ExcursionMJ
IN
2000 Ford Excursion
If you just bought it a few months ago, they should replace it. It could be that your wiring going into the hub sensor is bad though, like a bad pigtail. Either way, if you think it's bad they should replace it.
hockeyadc
NJ
2002 Ford Explorer
You mean the wiring that is coming from my car to the hub itself? I replaced the entire hub so the wiring from the hub/abs is new. How would I check the car wiring?
ExcursionMJ
IN
2000 Ford Excursion
Yeah from the actual car to the hub. As far as testing that actual pigtail, I will get back with you shortly.
