Tony@MTVA
- September 13, 2016
- Millers Tavern, Va.
- 2007 Ford Explorer / EB
I have a 2007 Ford Explorer Eddie Bauer 4wd. I am experiencing a bad bearing type of noise in the front end. It is a rotational noise. It is most pronounced at lower speeds while coasting although I the noise is there all the time except it not as noticeable a high speeds. Anyway the noise stops as soon as you put in in 4wd high while moving and starts back as soon as you take it out of 4wd high. My mechanic has checked all the normal things, wheel bearing play, cv joints, brakes, u joints and can not find the problem. Surely someone out there has had this problem and has the solution. Help Please!!
