1998Exp
- December 5, 2010
- Seattle WA
- 98 Limited V8 AWD
Noticed intermittent disengagement of cruise control in my '98 Limited. For whatever reason, self-diagnostics of the cc servo don't work in this model - perhaps because there are more buttons on the steering than in the plain vanilla models. When the cc failed, some years ago, I was forced to take a guess and replace the servo -- which fixed it. But then it refused to engage, while now it abruptly disengages in a random fashion. My suspicion falls on the notorious pressure switch that caused fires in the past. Ford's cure was to add an inline fuse, and I had that done, but the original switch remains. I can't see any external signs of failure, like fluid leak. Can't tell if the thing even works at all, because it's a backup, and the primary sensor for cc disengagement is the switch on the brake pedal - which is fine. Guess I could test it by disconnecting the brake pedal switch, but who wants to be on the highway with disabled brake lights? The switch is just $25 on Amazon, but I hate to throw money at a problem. I could check it by stepping on the pedal, but what will this tell me? If anything it randomly senses pressure when there isn't any. Any ideas?
