WidgetTrac
- April 17, 2012
- Cypress, TX
- 2001 Sport Trac 2wd
...Aside from consumables - filters, oil, brakes, batteries - the only thing i've had to replace was the thermostat... a $5 part! I'd call that low-maintenance...
Yeah, and I'd call THAT a jinx! Some idiots just don't know when to shut up...
OK, so i've noticed lots of times my '01 ST is a little slow to start - it cranks over enthusiastically, but takes several stumbling sputtering attempts before finally firing up, and then runs rough or dies if I don't give it some gas. Usually it starts fine, just _sometimes_ it does that.
Today I was running around town, made several 15 min. stops, at the last one I was in&out in 2 minutes, 'trac wouldn't start.
It seemed to be trying to start a little at first, just a stumble here & there, then just steady cranking... At least I know the battery & starter are good, for now anyway.
I tried cycling the ignition switch a few extra times to build up fuel pressure, but no joy. No improvement after 15 min. After an hour it started right up. Tank is about 2/3 full right now.
So i'm thinking fuel pump because it was hot as hades today and I was in a lot of traffic so under-vehicle temperatures would be high, and it's at the age and mileage where pumps go bad I think, and the "way" it wouldn't start made me think fuel, and most especially because the 1 hour cool down cured it. (hood up, partial shade)
But is there anything else I should be looking at?
Any tips/tricks to dropping the tank?
Found a good price on a new pump?
