Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
Since I've gotten the 5.0 running I've filled and drained the coolant a few times as I've repaired different systems. I checked the coolant about a week ago it's now been in the cooling system for several weeks and noticed it had a black hue to it. I wasn't immediately suspicious because when coolants mix it can make a darker colored coolant. There was the old coolant in the system when I did the flush and I have no idea how old or what brand it was but it looked terrible. I put new coolant in after running a cleaner and distilled water through it. I thought all was good with the system, it never leaked and the engine temperature stays where it should. After running the engine several more times I decided to take a look in the radiator just to make sure it had plenty of fluid. I checked the coolant expansion tank and it was still full but when I looked in the radiator the coolant was a few inches from the top. I topped it back off and ran it for a while and checked it the next day. The coolant was fine in the expansion tank was fine but lower in the radiator again. Upon further inspection I noticed a trickle of coolant right around the tube where the hose for the expansion tank hooks to the radiator. I pulled the rubber hose off and took a good look at the hose and the plastic tube it connects to. The hose was in good condition but on the radiator where the hose connects there were imperfections and deep gouges in the plastic that coul allow air or coolant to escape. Now I'm assuming the radiator must be replacement based on the poor QC. I took some high temp in weld and filled in the gouges and filed the raised seams so the rubber expansion tank line would have a smooth surface to connect to. I cut an inch off of the rubber tube and after I let the in weld cure I reconnected it the radiator. I borrowed a radiator pressure checker from oreillys and hooked it up, pumped it to 16lbs and started to hear dripping. I looked under the the car and my waterpump to lower pipe hose was leaking. I wanted to replace it when I replaced the pump but the old one seemed a better fit than the AC delco brand hose I'd picked up to replace it, so I just used the old one. Ironically, when the truck is running whether its up to temp or not it doesn't leak a drop. So I'm going to replace that hose and pressure test again but now I fear the head gasket is blown. I got the truck up to running temperature and I looked in the expansion tank and can see air bubbles coming into it but no visible leaking from anywhere. My oil is very clean with no coolant in it, I need to check my coolant color again but when I drained it last time it was dark but didn't have any oil in it.
Before I start taking the heads off is there anything/anywhere else I should look for? Others tests I should perform? Once I have the heads off do I need to go to a machine shop to have them checked? I understand heads can warp and crack, I just want to make sure I do it right so I don't have to do it again.
This is the gasket kit I'm looking to use as a replacement for the others https://www.rockauto.com/en/catalog...e,cylinder+head+gasket+/+head+gasket+set,5412
