m.dongle
- January 8, 2006
- San Antonio, TX
- '92 XLT Standard
I have been having somewhat erractic shifting problems. Most notably, the shifter will slips out of 5th gear and into neutral. I can hold the shifter into 5th position and it will stick but that is not a solution.
Also having a slight grinding going into 2nd gear. This is not a serious issue, I can double clutch and often get into second. Or I have also been known to bypass 2nd, going from 1st to third.
I was told that a bad shifter bushing could be the cuse of the slipping into neutral. Is this difficult to replace myself?
Are there any other ideas / opinions?
TIA
TIA
