bad vibration when coasting | Ford Explorer Forums - Serious Explorations
Barcuss
Auburn Georgia
95 XLT
I have a 95XLT 4x4, when ideling or driving through our subdivision no problems at all. But when I get out on the main raod of get above 35mph it starts to vibrate and gets worse if I let off the gas. Nothing at all like a tire out of balance, it feels like gears are not working together as they should. The vibration also seems to have a hum. The vibration starts at 35mph and continues as fast as I can drive, but I have not got above 60mph and it still is vibrating and get a littlle worse if I let off the gas, if I push the gas a little more the vibration will get a little eaiser but will NOT go away until I get back below say 30mph or so. Thanks for your help with this problem...
Check your U-joints and driveshaft maybe??? I am a first generation owner so i don't know do those things have CV joints?. Check those.. Is it a shake or a vibration?. With the hum it sounds like it could also be a wheel bearing. Good luck..
Hi, i assume u have a manual shift? I would start with the basic checks. try gettin it up to normal speed and shift to nuetral, (manual or auto trans). this is a good way to check for bearing noise. If the noise is still present while coasting, I would lean toward a bearing. If the noise stops while coasting, you prob. got a driveline prob. I just had to replace my rear end. Mine would roar when i gave it gas, but stopped when i let off gas, putting torque on the driveline should make the noise greater. If it passes the coast test, prob. a trans (manual) or a rear differential prob.. hope this helps...good luck ;)
Oops, by the way could allso be in the drive shaft....it would give more vibration than noise....
It is an automatic transmission (4R55E). I will check all the above this afternoon. Thanks for the help...
sounds like drive shaft or transmission related and possibly CV joint
George
Have you checked the fluid levels in you T/F case and tranny?
