Baffled at the power steering
dleague
Cincinnati, OH
04 Explorer EB Edition
Ok Im a little baffled at the power steering issue I have going on. I own a 04 Explorer EB 4.0 V6. About 2 weeks ago I noticed its feels like the power steering is starting to go out. If I turn the wheel slightly to the left or right it almost feels like its starting to whine/squeal but it still keeps the power steering and is easy to maneuver. It doesnt get tight or anything. If it drives right in the middle, aka the sweet spot, it drives fine and there is no resistance or anything. I have checked the belt and it seems fine (no cracks or sheen). I also have been keeping an eye on the reservoir to see if Im leaking any fluid and its not. Spoke with another person and they seem to think it could be the bearings going bad in the pump??? So Im debating if I want to replace the pump. Nervous that may not fix anything. If I do replace the pump, how easy is this? I dont mind doing the work and I replaced one before on a Durango I had but have never done it on my Explorer.
Just baffled and dont want to throw money at something that isnt going to fix the problem. :scratch::feedback:
G 02 Explorer XLT Overheating - Baffled in NJ Stock 2002 - 2005 Explorers 5
D Baffled by Temp sensor Stock 2002 - 2005 Explorers 7
9 HELP! Alaska Winter = MAJOR electircal glitches! I'm baffled! Stock 2002 - 2005 Explorers 4
mfitz725 03 EB POWER WINDOW PROBLEM Stock 2002 - 2005 Explorers 2
mfitz725 03 EB 4.6 Power Window Problem Stock 2002 - 2005 Explorers 0
D AC no power at the compressor Stock 2002 - 2005 Explorers 0
2 No Power P0300 Code Stock 2002 - 2005 Explorers 2
M Lessons learned, electrical issues (door ajar, power windows, out side rear view mirrors, power locks) Stock 2002 - 2005 Explorers 2
L parts list for replacing power steering pump Stock 2002 - 2005 Explorers 5
N Power steering hose hold down inverted torx size? Stock 2002 - 2005 Explorers 1
M power steering fluid leak 225,000 Miles Stock 2002 - 2005 Explorers 1
P Loss Of Power Engine Stutter Stock 2002 - 2005 Explorers 2
M how much power steering fluid should I buy when I flush the powering steering system Stock 2002 - 2005 Explorers 1
B 2002 explorer power seat Stock 2002 - 2005 Explorers 6
G 02 v8 explorer power steering hose leak Stock 2002 - 2005 Explorers 0
T Solved Fuel pump power issues after transmission swap. Stock 2002 - 2005 Explorers 5
I I need help with a power drain on my battery Stock 2002 - 2005 Explorers 1
P Where is my pcm power diode? Stock 2002 - 2005 Explorers 4
M Dash lights, loss of power steering, no oil pressure Stock 2002 - 2005 Explorers 2
I Dealer Installed Remote Start, Power Code?? Stock 2002 - 2005 Explorers 1
I Power Code Remote Start Stock 2002 - 2005 Explorers 0
L repairing my power steering Stock 2002 - 2005 Explorers 2
M ONLY driver power window works. Possible causes? Stock 2002 - 2005 Explorers 0
U no rear power windows Stock 2002 - 2005 Explorers 2
W No gauges, radio or power windows. Stock 2002 - 2005 Explorers 2
S Power front seats into a base model without them? Stock 2002 - 2005 Explorers 5
2 Power Accessories Won't Turn Off With Car Off? Stock 2002 - 2005 Explorers 3
D Oldie but a goodie w/ power seat issue Stock 2002 - 2005 Explorers 6
S First: Door jamb wiring/ power window issue.. NOW: No dash cluster, radio, AC!?!? Stock 2002 - 2005 Explorers 6
S Lower windows without power Stock 2002 - 2005 Explorers 4
R How do I remove 12V power point on console Stock 2002 - 2005 Explorers 1
E 2002 Explorer XLT power door locks Stock 2002 - 2005 Explorers 0
M No power Stock 2002 - 2005 Explorers 4
M power steering fluid replacement Stock 2002 - 2005 Explorers 3
D Front passenger power pindow switch turns off when pressed Stock 2002 - 2005 Explorers 0
D Power window won't pull up Stock 2002 - 2005 Explorers 12
R Power locks, drivers power seat, cig lighter, and keyless wont work Stock 2002 - 2005 Explorers 0
L badly leaking power steering fluid Stock 2002 - 2005 Explorers 8
V Huge power loss from engine. (Misfired detected) Stock 2002 - 2005 Explorers 3
A 2005 Exp. power windows intermitent Stock 2002 - 2005 Explorers 0
D no power to wheels... Stock 2002 - 2005 Explorers 4
J FUSE ISSUE NEED HELP.... NO Turn signals,radio,power windows or fuel gauge Stock 2002 - 2005 Explorers 6
P 2002 power mirror replacement Stock 2002 - 2005 Explorers 5
M Poured some windshield wiper fluid into the power steering fluid reservoir Stock 2002 - 2005 Explorers 16
B 2003 Eddie Bauer 4.6L P1299 Code and reduced power mode. Stock 2002 - 2005 Explorers 2
J Explorer Shut Off On Highway With Reduced Engine Power Stock 2002 - 2005 Explorers 10
R Power seat fuse keeps blowing Stock 2002 - 2005 Explorers 2
2 Power steering replacement Stock 2002 - 2005 Explorers 6
P power windows issue Stock 2002 - 2005 Explorers 1
B 2005 Mountie rear door power window? Stock 2002 - 2005 Explorers 1
Similar threads
