dcdyd
- January 7, 2011
- Eden Prairie, MN
- 98 Explorer
This is the first time I do a coolant drain and fill and I have some basic questions. From what I read procedures for coolant exchange are described below.
1) Drop the lower radiator hose and drain the coolant.
2) Fill distilled water and run the car about 10 minutes while turning the heater to maximum.
3) Wait until car cool down and drain coolant again.
4) Repeat 2 and 3 if necessary.
5) Fill 50/50 coolant water mix and that is it.
My questions are below.
a) After step 3, will there still water remained in the cooling system?
b) Since there is certain coolant remaining in heat core after step 1, would the water be mixed with the coolant in step 2? If yes, after step 5, the coolant in the system would not be a correct 50/50 mix. Am I right?
