bats
- October 30, 2009
- NY
- 88 Bronco II
First up is the tab I welded on. The soft lines follow a similar route as a stock one. The wetness is spray paint. It's straighter once it was all finalized.
Wheel side of e-brake cable. I was tired last night, okay?
The tension bracket I made years ago. Just bent flat stock with two holes in it.
The cable clamps serving as the intermediate e-brake cable. Nothing more permanent than a temporary fix.
Progress! The e-brake cables DID fit in the slot. I just had to bend the tabs a little and wiggle it just right. Re-used those torpedo looking things that the axle side cables clip into and took up the slack in the steel cables. Those little clamps were still nice and tight after all these years and unbolted nicely. Need to adjust the e-brake shoes but I didn't feel like taking the calipers off tonight.
Parts list so far:
East Coast Gear Supply Right Backing Plate 96-01 Explorer
East Coast Gear Supply Left Backing Plate 96-01 Explorer
East Coast Gear Supply 8.8 Brake Line Kit
I used a 99 Ford Explorer as the reference vehicle on Rock Auto. Standard brake hardware and e-brake cables. Make sure you get the ones with the slot on the end as shown, not the knob. From what I can tell, the axle side cables are the same on the two door and four door but the intermediate parking brake cable is what's different. (Not that it mattered here.)
Parts list so far:
