Betsy98Sport
- April 30, 2010
- San Diego, CA
- 98 Explorer Sport Wht 4.0
So the Explorer was starting good and then one morning the Sport just wouldn't start. When the trying to start, all I get is one click. Not sure if it's the solenoid engaging or the gear shooting out. The voltage is good on the battery and I've had it tested and charged twice at Autozone. I removed the starter as well and had that tested. It worked great at Autozone as well.
Today I measured voltage across the starter to the battery on a few spots:
1. Battery (-) to yellow ignition wire (S) - only 10.5 V when key is turned to start
2. Battery (-) to positive starter wire (B) - ~12 V +/-0.10
3. Starter Ground wire to battery positive - 12.14 V
4. Battery (-) to "solenoid to motor terminal" (M) with ignition wire (S) jumped from Battery (+) terminal - ~12 +/-0.10 V
5. Starter ground strap (attached to bottom starter mount bolt) to (M) terminal with key turned on - 11.98 V
Pic for reference
All the wiring looks like its checking out good unless the voltage going through the yellow ignition is not good. When trying to start the car I noticed the solenoid gets really hot. Possible sign that the voltage is not going to the starter.
I still think its the starter. Any thoughts?
Pic for reference
