brentandlorie
- March 29, 2007
- Meridian Idaho
- 1992 xlt
1992 xlt 4wd..208,00 miles and runs great, except...
Battery drains slowly over time to the point it kills the batteries ability to recharge. Robs its ability to store cranking amps??!!!
I can jump it. battery won't hold cranking amps after about 6 months. Walmart, bless there ignort hearts, keeps giving me abrand new battery on waranty, but i need it to stop!
One thing that baffles me is, when i turn the truck off, I hear a whirring noise and then a few clicks. Sounds like it is coming from the power dist. box?
Does anyone else hear that? seems like a fuel relay, but shouldn't I hear that when I turn the key on, not off?
what I have done:
cables lok good, terminals cleaned
fule pump relay and fuse replaced
starter ( old one was working, but pulling 13.2 amps from battery instead of normal 12. I figured this was slowly killing the battery, but no!)
ignition cylinder ( was pretty worn, key off center, loose in core)
ignition switch ( old one was not running smoothly, sticking)
any help would be greatly appreciated.
what I have done:
