bkb88
- April 22, 2010
- 94' Eddie Bauer
Hey guys I have a problem with my battery losing voltage after being parked overnight. I recently found a parasitic draw that read over .400 amps which from what I have read on this forum is enough to drain the battery overnight. I found the circuit that was causing the problem and it ended up being the premium radio amplifier that was causing the draw. Seeing how I use an aftermarket radio I just removed the fuse and dropped the draw down to .005 amps. About 3 weeks ago I had my battery switched out through the warranty at walmart and it was going dead about every couple of days for the first week then after that it was going dead after parking it overnight. Now the battery seems to not be holding a charge for very long at all. I have had both the alternator and the battery tested and they both seem to check out fine. Could I have a bad cell in my battery?? :scratch:
