BBK SC QUESTION
explorer4
palm harbor, florida
92 explorer sport
hey i was reading your supercharger install and was wondering if some how i could buy the timing retard and the fuel regulator from bbk I saw that the kit is 3500 and that there is a 299.00 additional package that you need for the computer, it it possible you think for me to just buy that 299 kit and beable to adjust my timing and fuel from insid elike you, what do you think,?
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Dunno where you got that info from. The kit is $2400 + $400 for the installation kit. I haven't heard of the computer being sold separately.
If you just wanted the computer with the timing controller, it would probably need to be a custom thing. The computer is supposedly custom programmed for each application, and as far as I know has never been used without the supercharger. The computer install was actually one of the hardest parts of the supercharger install, as it involves tapping into about 25 circuits in the X's computer and electrical systems.
As for the fuel, it would be easy to add a secondary FMU like I have. It is connected via a vaccuum line to the new computer, but I don't know if that's necessary. The FMU is made by another company, forgot who, for BBK. You could probably find out who and buy directly from them, or from Jegs or Summit or something.
Good luck!
explorer4
92 explorer sport
ok, but heres another question, i heard that the xplorer computer can adjust the timing by +/- 2 degrees. It does this by using the knowck sensor. I just read that for every 50 hp shot of nos you should retard timing 1/2 degree, so technically i wouldnt have to get a chip made because in theory the computer can retard the timing up to about 200 hp. not that it can take it
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
you're correct, I just dunno if the stock computer can react fast enough so you don't fry a cylinder. Just so you know, when I first installed my ZEX kit, one of the nozzles was mis-cast. I ended up having a 200 shot nozzle in there and ran it. Nothing happened besides me frying my #2 sparkplug, the nitrous just went out the exhaust. I'm glad nothing worse happened, but the computer did not adjust in time :eek:
explorer4
92 explorer sport
did you feel a huge hp increase with the 200,
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
none, like I said, everything f***ed up and the nitrous just went out the exhaust. Glad I didn't have any engine damage besides the plugs.
Jason_25
Elite Explorer<br>ECX Member
New Bern, NC
'95 Explorer "Expedition"
Your '92 doesn't have a knock sensor. Only the 97+ SOHC explorers have these.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Well, there ya go (though mine can still modify timing a bit on its own).
vroomzoomboom 75mm BBK throttle body problems Need for Speed! 27
Dan Whitaker BBK 5.0 Intake ??? Need for Speed! 6
C BBK Supercharger Need for Speed! 10
C Cam question Need for Speed! 0
J header question Need for Speed! 8
D 96 5.0 cam question Need for Speed! 9
Scott B. AOD / 4R70W Gear Ratio Question Need for Speed! 5
Scott B. 302 Stroker question Need for Speed! 3
Scott B. 5.0 L Intake Question Need for Speed! 1
Scott B. V8 Motor Mount Question Need for Speed! 7
D 97 5.0 X question Need for Speed! 4
A Quick question about air intake Need for Speed! 8
O 4R70W 3000 stall and towing question Need for Speed! 28
I 2nd gen 5.0 exhaust port to steering shaft question Need for Speed! 2
htrdlncn Question about X-Charger Need for Speed! 3
Makahveli Return to stock injectors? and a compression question.... Need for Speed! 13
J Question Megasquirt & Our Automatic Transmissions Need for Speed! 16
S Twin Turbo Question Need for Speed! 12
L Wheel size and performance question. Need for Speed! 2
Makahveli Another question for bypass/blowoff valves Need for Speed! 0
N Quick header question Need for Speed! 1
section525 Speed and power question Need for Speed! 20
V Question on spark plugs for nitrous system Need for Speed! 8
R fuel injector upgrade question Need for Speed! 4
T another freakin exhaust question.... Need for Speed! 3
S SOHC 4.0 Cam Question Need for Speed! 12
L question for the ZEX users Need for Speed! 6
E Hey question for alec Need for Speed! 14
james t help; troll & blk mk8 charger question Need for Speed! 9
