medmo54
- December 14, 2012
- ND
- 2002 Ford Explorer 4.0L
I'm having issues with my 2002 Explorer 4WD 4.0L -- it started with a slight "humming" noise from the front end...can start to hear it at about 20 mph and gets really loud at 30-40 mph -- then seems to go away after about 50 mph. Here's what I have checked/replaced:
1. First, really thought it was a wheel bearing as they seem to be pretty common and really sounded like it was coming from the left front -- also, ABS light is on. Replaced left front wheel bearing -- no change in noise.
2. Wondered - maybe both wheel bearings were bad or I replaced the wrong side? ABS light still comes on as well. Put ohmeter on hub (ABS speed sensor) I removed, no resistance --- checked new one I put in and shows .856. Checked the right front and that one doesn't have any resistance either. Went and got another bearing and replaced right front -- noise and ABS light both still there.
3. After researching I am wondering if I have a front diff problem. I haven't pulled the cover off yet to look but am willing to -- just wanted to get some feedback. I thought about CV axles but doesn't seem to be similar to ones I've dealt with in the past....
4. Full symptoms -- humming/bearing type noise now heard pretty much all the time but worst at 30-40 mph. Lock into 4wd and gets louder yet. Turning left or right doesn't seem to effect the noise much. Noise can almost be "felt" under feet on drivers side floorboard. No popping/clicking noises while turning regardless of speed. Noise goes away periodically if I let off gas (ex....if I take off from a stoplight noise starts to get bad about 30 mphs -- if I get to my cruising speed and lightly let off the gas it seems to go away as quickly as I take my foot off the throttle -- but as soon as I apply any pressure to gas pedal again it comes right back.) Noise pitch changes with actual speed and not RPM's.
Any help would be great...maybe others have had this same issue? I've researched on here alot and find alot of similar stuff but almost every single one of them seems to end with a bad wheel bearing -- wish that was the case for me! (I've come to the conclusion also that maybe the ABS issue is something more wiring related or possibly in one of the sensors in the rear end....I will diagnose that further to make sure it's not a wiring issue or whatever -- this noise just really worries me)
Thanks in advance!
Thanks in advance!
