stilbo
- May 30, 2000
- Bloomington, Indiana
- 2015 XL Base
Bought my fifth Explorer today.
First GEN III
2002 Explorer XLS with quite a few options for an XLS like rear air, 16 factory alloys, third seat and side steps... 74,000 miles, one owner, CarFax is good and it's a clean truck. Bought it on ebay for ..... $3500.00 I think the NADA on this thing is about $8500.00 retail.
I don't think I got hurt on this deal even if: It misfires and runs rough. I bought it knowing CEL was on but the auction/dealer said it was "engine in need of service". More like engine in need of replacement?
I took my Auto X-Ray scanner up to Waukegan, IL and the pcm was loaded with P304,305,306,316.. I couldn't pin point these in my code print outs but the scanner said "misfire in multiple cylinders". Okay.. I clear the codes and said screw it and drove it 92 miles back to Indiana to my shop. Ran like crap but made it and I didn't care at this price if I stuffed a piston into a wheel well. It threw one code halfway home: "Misfire in cylinder number three". I thought'' okay this is good! Plug? (crappy Motorcraft platinums) Plug wire?
I get it home and throw the fan on the engine to quick cool things and pulled # 3 plug and... it's carbon fouled... COOL! I thinks.. so I replace it and the next five plugs with Bosch Platinum standard plugs (DEATH TO MOTORCRAFT/AUTOLITE PLATINUM PLUGS!). I get to # 6 (driver's side rear) and notice the plug coming out not as easy by means of fingers as the other five... Gets plug out and: GROUND ELECTRODE BENT TO ONE SIDE AND CENTER ELECTRODE AND INSULATOR BENT ALL THE WAY TO ONE SIDE INSIDE PLUG CAVITY.
UH OH...
Well... that sucks I thinks to myself. The only other time I've seen smooshed plugs like this was in extremely high rpm motorcycle engines when valves have let loose or pistons fly off their wrist pins. But those engines don't go 90 miles more at 65 mph! There does not seem to be any mechanicl noise like scraping, clicking, clanging, knocking, etc, and I drove the damn thing 90 miles at 65 mph and nothing came out the sides of the block, the temp and oil pressure are fine but the damn thing still runs rough.... like maybe an intake or exhaust valve is not there any more?
WTF would make one of these Cologne motors self distruct like this?
Anyone else here ever take a plug outta their 4.0 and have the electrodes smooshed sideways?
I've put over 600,000 miles on four other 4.0 Explorers (OHV pushrod motors) with absolutely no problems other than intake manifold leaks on the '93 that retorqueing fixed.
The CEL has not come on yet so I'm gonna cycle it tomorrow and try to throw another code. I'm gonna replace some plug wires too with some known good ones I have in the shop.
I keep thinking (wishing) that that smooshed spark plug went INTO the head like that after one of the simian "mechanics" at the sales facility ran it over with a D-8 bulldozer before installing it, but I'm not counting on it..
Been pricing engines locally and found a couple "B" rated engines, complete with under 80k miles for $675. I'd just pull the LH head and peek into the cylinder but that's about as much work as R&R the whole damn engine... If a valve did get loose can I tell by just pulling the valve cover and checking the cam followers? (I'm a 4.0 OHV guy remember) And if a valve did go bouncy bouncy bouncy on top of the piston the cylinder walls would no doubt be toast too... weird thing is, there is not any signigant blow by or pressurization of the crankcase. I'd expect that if a valve DID flop around in there, the piston would have a very large hole in it's poor little crown...
Anyway...
If anyone has any useful, interesting, amazing or even spiteful comments... have at it please.
Thanks....
rds
First GEN III
UH OH...
Anyway...
Thanks....
rds
