esromj
- January 14, 2014
- Madison, WI
- 2001 Explorer Sport Trac
I have a 2001 Sport Trac Job 1 (June 2000) with SOHC 4.0. I have 0171, 0174, 0301, and 0302 codes. I had a smoke test done and confirmed there is a leak in the upper intake manifold gasket.
What is the best replacement gasket? I see gaskets from Fel-Pro (MS90890), Magnum (MS18037), and Victor Reinz (MS16375). Which of these is the best and are there other brands that may be better?
Should I plan to replace the lower intake manifold gasket or is that a waste of time if no leak has been found there?
Are there any other gaskets/o-rings that should be replaced concurrently with this job?
How can I tell if the intake manifold is warped? Is warping easy to see if the manifold is sitting on a flat surface? Is warping a rare problem I shouldn't worry about?
