Best oil pump for 2001 4.0 SOHC???
ETHACK
nv
2001 X SOHC 4x4
Replacing motor in ol truck and not sure on what oil pump to get, OE a high volume melling, or regular ??? If Melling which one? Parts house says M68A, Amazon says not, so??? Also do I need to get a melling pick up tube and screen or will OE work??? Not a mechanic and all advice is great, this site is awesome and everybody on here has been so helpful it's really appreciated TIA everybody!!!!
donalds
Location
Stem
Nc
1999 ford explorer sohc
I'd say both are a great option the milling with the all metal pickup tube would be my choice
ETHACK
nv
2001 X SOHC 4x4
Thats what I was thinking definitely metal, also will most likely put in a pre oiler, so not sure on the HV pump, as not sure how or if there would be any backflow internally at the smaller chambers, and if so how that would/could effect long term. You know alot of stuff and I really TY for all your input, I know alot of ppl don't take the time unless it's to criticize so again TY.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
I typically use Melling pumps.
donalds
Location
Stem
Nc
I use a pre oiler with the milling pump and screen
Been going for 3 years that way now
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
The OEM oil pump is very good, fine for any mild engine build. Don't ever use a high volume pump unless you truly need it, which means very high rpm, bigger pan capacity and baffling, plus bearing clearances made for the higher volume. Skip high volume, it's much harder on the pump drive shaft also, will twist the stock shaft easily.
Melling makes great oil pumps, but they make so many, some may be larger in housing size, require special pickup etc. I'd hunt a replacement part that takes the original pickup.
I installed a new OEM pump in my 99 SOHC, in 2006. The old one had 77,450 miles on it, now a spare stored in the pump box, they're good pumps.
ETHACK
nv
2001 X SOHC 4x4
TY!!! Thats what I was wondering exactly about the HV pump, thanks for the clarity, OEM pump and pre-oiler is way I'm leaning towards, oiler after motor is back in and on the road again.
donalds
Location
Stem
Nc
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
I don't recall my 99 having a plastic pickup, which would bother me also. what I said applies to many engines, aftermarket pumps can be larger and require odd pickups. My Melling standard oil pump interfered with the metal oil pan, and even the aluminum spare I had. The cover bolt heads were slightly deeper than stock bolts.
