best place to put amp | Ford Explorer Forums - Serious Explorations
middie8
Conshohocken, PA
1998 Eddie Bauer
98 EB---will under the back seats work or should i go with the back the back seats?
that being said, where to ground?
thanks in advance
ive got mine under the back seat, i like i there.
Depending on the size of your amp(s). If they are small enough you can probably fit them behind the panels in the back, but you need to be sure they are properly set. You can check my page on cardomain in my signature to see how I did mine.
whatever you do, LET IT BREATHE.
i can't stress that enough, unless you want your amp dead in a month or two from letting it over heat. or it could possibly cause a fire.
i recommend somewhere in the open unless you have a nice cooling system setup
To ground: Pick a spot in the floor and drill a hole. Make sure you're not near the gas tank or any wires. Remove some paint with sandpaper to get to bare metal and ground with a self tapping screw.
I put my amp under the rear drivers side seat, too. Perfect spot for a medium sized amp.
