wwhitby
- August 25, 2007
- Prattville, AL
- 2002 XLT
All,
I'm working on getting our 2002 Explorer XLT running for my son to use. Its been sitting for a while, so I know the gas has gone bad. My first task was to drain the gas tank. Its about 3/4 full of bad gasoline.
I found out about the anti-siphon screen that Ford put in the filler hose, so I figured that I would remove the filler hose at the tank, then put the hose to the hand pump in through the filler hose. I inserted the hose in through the filler neck on the tank and had bad gasoline rushing out at me. I guess I made it past the check valve. Fortunately, the Explorer is parked outside and not in the garage! I'm not sure how much I lost, but its not completely drained. So that way isn't going to work.
I really don't want to cut an access hole through the body, so is there another method I can use to drain all that bad gasoline out of the tank?
Thanks,
Whit
Thanks,
Whit
