Best Way to Hook Up Amplifier
redsox26
Fairfax, VA
2007 Explorer Eddie Bauer
Today I just sold my 2003 Ford Explorer XLT and got a 2007 Eddie Bauer Explorer. In my 2003 I had Two 1000W Amplifiers hooked up to the stock head unit (one for my aftermarket door speakers and the other for my two 12" subs. I had to leave my aftermarket speakers in the doors because I got rid of the stock one but was able to salvage everything else. I plan on hooking up one amplifier to the 2007 stock head unit for the two subs and selling the other amp. Since my 2007 doesn't come with a subwoofer (no subwoofer outputs) I am trying to get some opinions on how to hook up the amp. In my '03 I had just hooked up an aux converter piece to the rear speaker wires and ran that to my amplifier inputs for the subwoofers. I would like to avoid doing this because then the sub plays more of the higher frequencies and doesn't sound the best it could. Since there is no subwoofer as part of the stock system, is this my only choice? And if not what would you recommend??? Your help and suggestions would be greatly appreciated.
-Alex
$TheMoneyPit$
elkton maryland
1992 mazda navajo&97 xlt
theres two things you can do what you had was called a line drive converter and thats what you had or replace your head unit with a aftermarket with rear subs out and make sure you dont run all your wires together try and keep your rca's from any power wrires espeically the power for the amp most people run them under the door sills which is the plastic thats screwed down by the doors and run it all together if you do you will get ground loops or rf interfernce in your system and will sound like garbage
redsox26
Fairfax, VA
thanks for the info. little short on money right now so im probably gonna stick with the line drive converter but i'll be sure to keep the wires away from the power cord. Now i know where that interference was coming from on my $500 dollar install job on my 03!!!!.....
$TheMoneyPit$
elkton maryland
it cost you 500 to get it installed thats outrageous
E How best to sell some stock stereo parts. Explorer Audio & Navigation 1
R Best kit to install a double din headset?? Explorer Audio & Navigation 0
RyansX Best bang for your buck? Explorer Audio & Navigation 8
K best low buck option for replacing stock 2000 sport speakers Explorer Audio & Navigation 11
K Best way to wire in a jack for iphone/mp3 player?? Explorer Audio & Navigation 14
J What is the Best Single Subwoofer For My Amp? Explorer Audio & Navigation 19
J best settings for pioneer amp and headunit Explorer Audio & Navigation 2
D Which wiring kit is best?! Explorer Audio & Navigation 7
S What is the best install kit for a double din going into a '02? Explorer Audio & Navigation 3
B Tell me the best way to fix my problem. Money is of no concern. (Electrical Issues) Explorer Audio & Navigation 70
H Best low tier alarm / starter? Explorer Audio & Navigation 2
E Best System In '94 Explorer? Explorer Audio & Navigation 10
B Best way to check polarity? Explorer Audio & Navigation 0
T best AM stereo install kit.. Explorer Audio & Navigation 5
Charlie Are Best Buy & others wiring subs wrong? Explorer Audio & Navigation 1
SDVike Best GPS for offroading Explorer Audio & Navigation 6
E What's the best option for a sub? Explorer Audio & Navigation 19
1 what is the best way to bridge my subs Explorer Audio & Navigation 15
5 Best bang for the buck Explorer Audio & Navigation 5
E Best place to run through firewall? Explorer Audio & Navigation 9
E Best place to hide an amp? Explorer Audio & Navigation 51
I What is the best kind of ampfor my sub Explorer Audio & Navigation 2
F Best HU under 400 bux Explorer Audio & Navigation 5
M Best single subwoofer on the market? Explorer Audio & Navigation 57
S Best Amp for RF Sub Explorer Audio & Navigation 2
K Best size speakers for doors Explorer Audio & Navigation 19
M BEST 6 1/2s for $100-250 - List! Explorer Audio & Navigation 1
M High powered system - Best cables? Explorer Audio & Navigation 12
M 12" Alpine Type-R Questions - Best Amp? Explorer Audio & Navigation 31
D Why does Best Buy website say no stereos fit my '95? Explorer Audio & Navigation 8
J Best Car Stereo for my X Explorer Audio & Navigation 42
S best way to add bass w/o sacrificing cargo space Explorer Audio & Navigation 14
T Best Way to run new speaker wire 98 XLT Explorer Audio & Navigation 32
toddious best replacement sub, and can i use an 8"? Explorer Audio & Navigation 19
J best replacement speaker Explorer Audio & Navigation 2
F Best amp? Explorer Audio & Navigation 3
9 imitation is the best form of flattery.... Explorer Audio & Navigation 6
C Whats the best sub woofer for $350 and under? Explorer Audio & Navigation 45
C for $350 or less what is the best head unit Explorer Audio & Navigation 10
M Best SPL setup??? Explorer Audio & Navigation 14
M whats is the best box? Explorer Audio & Navigation 6
R Best Amp for JL Audio 10" w3 Explorer Audio & Navigation 10
I best HU for 100-120$ Explorer Audio & Navigation 6
T best radio $300 or less Explorer Audio & Navigation 23
U CB choice(i guess this would be the best place to ask) Explorer Audio & Navigation 1
S 6x8/5x7 Speakers. Best of the Best. Explorer Audio & Navigation 27
C Best Amp for the Buck? Explorer Audio & Navigation 12
S which headunit is the best? Explorer Audio & Navigation 12
V Best route for power wire from battery to back hatch? Explorer Audio & Navigation 18
B Best In-Dash Monitor??? Explorer Audio & Navigation 10
Similar threads
