Savage Wolf
- October 2, 2000
- Mount Airy, Maryland
- '93 Sport v8 5.0
vervepipes said:what about stick welders? they're often dirt cheap at Crappy Tire on sale
IMO, choosing a welder depends on what you plan to weld with it (metal thickness/type) for most fab work on off road stuff, you can get by with a stick (SMAW)welder, which works great for 3/16"+ thick metal, IMO lighter gauges with a stick is too much of a pita. GMAW (Mig) with flux core, or even better gas sheiled solid core is best IMO for doing light gauge metal or production work, mig is also alot easyer to learn to run a bead with soon as you learn the machine settings, as others said you can weld thicker metals with out too much trouble (up to 1/4"). Finally there is GTAW (tig) alot harder to learn unless you have welded with a O/A rig, if so Tig welding steel is pretty close to the same as pushing a puddle with O/A, Tig has a few things over the other welding types, a good tig machine can weld just about all metals at any thickness, its also the cleanest welding process (no slag or spatter), draw backs are large though, tig boxes are $$ for a good one, its VERY slow, over all cost wise it is the most expensive welding process
As for what someone said about cutting metal, plasma cutters look nice, but really if you get one, you'll find that you really end up not using it very often
*Warning, All info in this post is mostly based on opinion YMMV...
