The window issue was due to the window pulling free from the clamp, so I cleaned the area with brake cleaner, and stuck a hunk of double sided foam tape into the channel, then forced the window into it. Now the driver window works again.
Also re powdercoated the wheels I had laying around in a bright silver color. I will try to get them installed tomorrow. The almost look like some old man sprayed em with aluminum paint, it is what it is and they are going on.
Hosed down the engine bay and it looks a lot better, then went about changing out a perfectly good set of spark plugs just because I wanted to know it was done. Still no evidence of a coolant leak, in fact all the pans are bone dry.
Eric, I will take you up on that overhead, please.
I was humoring myself on the way to the store, in my new found silent ride, jamming to James Taylor and hearing every note through a stock stereo.
THis made me realize I need to choose my battles, and since a new off road toy is in the works, this needs to just stay the way it is. I will work with the stupid purple trim, as it goes away once you are driving down the road, can't see or hear it so why mess with it?
Trailer hitch will be color coded to the darker trim.
A purple hitch, because I can.
