medicbro2000
- December 7, 2004
- Ludlow Vermont
- (1994 XLT) 00 RangerXLT
Hey guys,....ok AND girls!
thoughts i would add this in here as it may be informative for someone else doing ball joints.
I just replaced both left and right lower ball joints in my 2000 3.0 4x4 XLT ranger... We went to install the more expensive ones made by MOOG and found out they fit TOO LOOSE!! We had to put in the cheaper BOND Auto Parts Brand (Parts Master) ones but amazingly they fit nice and tight!
Case in point... loose fitting lower ball joints can wear your lower control arm over time and oblong the hole- hence eventually making you have to replace the WHOLE lower control arm....
So- be careful with MOOG lower ball joints... make sure they fit right... you may need to buy the cheaper ones and just have to remember to keep them greased up!!
Good luck!
Good luck!
