TJTurbo
- August 7, 2016
- Victoria, BC
- 1993 mustang
Hello there.
I just swapped a fresh 5.0 into a mustang, with the efi system from a 96 expo.
I will be using it for drag racing and a little bit of street driving to shows and meets.
I put a 35-425-8 Comp cam in it that i had around. reading later comp says not for use with efi. im just wondering if anyone knows why.
Comp specs are .513/.529 lift, 230/236 duration at .050
Im guessing because of the duration/overlap.
as it sits now, it will fire for a second then stall. if will kindof run if i hold the throttle open some, but not well.
Im talking with MGS Performance to see if they can get a tune for me.
any tip or info would be great..
thanks
thanks
